andrewcoon
- Aug 21, 2011
- 130
Hello on my motor I have 95psi compression but one has 60. Can I run it? Or do I need to re ring it before I start it?
Its a good system but drawback was 2 piece gear on crank , after 95 they are pretty trustworthy...But Can you trust the oil injection on these motors? Its an 88
I would see why before running as these rarely carbon up as 30psi difference is usually sign of damage...Hello on my motor I have 95psi compression but one has 60. Can I run it?
The cylinders of a chrome bore should not/cannot have any grooves at all in them and you cannot test with finger nail. The picture you posted show scuffing 360? around cylinder. That cylinder and piston is damaged. If the rest look like that find a block as yous cannot be bored on sleeved to repair.Very very minor groves. Passes finger nail test
