Since installing a volt meter in my boat I've been able to confirm that my batteries are indeed not being charged.
Whilst the motor is running , the volt meter shows 11 volts, no matter what revs.
So after reading the sticky thread about a regulator swap, multimeter in hand I tested the system.
Disconnect the 2 yellow wires from the stator and tacho stops working, volt meter rises a tiny bit, and at 3000 rpm Im seeing AC 18+ volts at one of the yellow wires to.
Is it normal for the other one to show nothing?
Question is, I'm assuming its the normal symptoms for a faulty rectifier? It actually looks damaged with some black gunk oozing out :
Already looks after market yeh?
Secondly, If I don't install and adapt a universal regulator, can I retro fit this rectifier?:
Rectifier 50 AMP Heavy Duty Universal RM Chrysler Force Outboard | eBay
Im also curious, my loom has 2 yellow, 1 red and oddly 1 grey wire goin to the rectifier, I've only read of them having 2 yellow, 1 red, 1 black?
