Does anyone have a wiring diagram for a 1988 Larson 18' Bowrider. I put in a new rotor/points/cap and got it running good, then when I went to shut it off, it wouldn't shut down. I used the carb choke to kill the engine, and fiddled with the key to see if the switch was going bad. I started it again, and then shut it down, no problem. When I tried the key again, I can't get any juice to anything- not the starter or any other electrical accessories. I thought the switch must be dead, so I bought a new switch and installed. I am still getting 0 volts at the switch from the battery. I have 12v at the starter solenoid, and the battery is charged. There is an inline fuse behind the dash panel on the power from battery wire, and it is ok. Is there another fuse/fusible link hidden somewhere that I should be looking for? I would appreciate if anybody can guide me to a wiring diagram so I can start to track down what goes where so I can troubleshoot this thing.
Thanks
Thanks
