Lower unit froze in Jan. breaking carrier, after 4 trips to shop, still not doing right. when I slow down, the prop makes a clicking sound, unless I put it in neutral. when I trailer boat, you can grab prop and if you pull back slightly it will turn while in gear and no pressure on shaft that could start engine. Also reverse has a whirring noise while in slow idle. Someone please get my confidence back in Yamaha. It never done anything but great things till it froze . could replacing carrier have caused these other problems?
