cheburashka
- May 28, 2005
- 715
I read all I could on stainless props and used a calculator to determine what would work for my boat--a '97 Maxxum 1900 SR bowrider with a 4.3 V6. The original aluminum prop was a Michigan Wheel three-blade 14x23, but for our use (pulling skiers and wakeboarders) the Mercury calculator said for a three blade we should go 14x19. I also read posts from a number of different people who have a similar set-up to mine and are using 14x19 props. The prop I bought was a Turning Point Express three blade stainless.
I installed the prop and it pulled fine up to 3000 RPM, but then it felt like it was cavitating and just spun freely all the way up to 4800. I thought I had a bad hub kit because it felt like it had spun, but I tried a Mercruiser hub kit and it did the exact same thing. I had the trim down to its normal angle and tried adjusting the pitch, but nothing seemed to make any difference.
I know I took a pretty radical step by going down 4 in pitch, but this seems like way too extreme of a change. Is it possible that Turning Point props have a different blade profile than the Mercury props? Is it normal to have that feel of cavitation if you're underpropped?
One other thing--this prop is vented with a single hole around 1/4". Not sure if that makes a difference, but I've never run a vented prop before.
