Rja91k5aolcom
- Jun 27, 2013
- 4
?1987? Nissan Ns50 keeps burning up one side of the coil I've put three on it and they keep going out in the first few minutes of running. Please help!
Welcome to Iboats,
Which coil is it, flywheel coil, ignition coil ?
Happy Boating
You are saying engine has burned 3 Ignition/CD units one after the other ? All in same area. If so, that's very strange. Were all 3 burned units, new or used units. Could you post a pic of burned area ?
Happy Boating[/
The motor had the original ignition/cdi unit on it. it started to run off and on one cylinder for a couple of hours run time ( not continuous hours or running) so i spoke with a mechanic he said sounded like coil. Bought one put it on and ran fine for about an hour then started to run on one cylinder again never ran on two until I put a second unit on it. Ran on two cylinders for less than 5 min an now it will only run on one cylinder. I've replaced plugs, checked for fire on both plugs and it only fires on one, I switched plug wires and checked firing and it still is not getting fire on that cylinder
