Re: Battery
No this isn't an ad for Walmart, but they and most other auto places will do a free battery test on it for you. They have equipment that basically draws it down, then recharges it, then tests it. I had a marine battery from Walmart that was brand new and would go flat trying to start the boat after say 4 attempts to start. They did a full test on it and said the battery was a bad one and exchanged it no sweat. The replacement works fine. Why go through the hassle of trying to find out if you have a 'draw' on the battery when you have the battery checked out first. As my boat is parked out front of my house on the easement, I have gotten into the habit of removing the battery from the boat when not in use and storing it in the garage. It also means I can put it on trickle charge if I want. By the way, if you need a trickle charge, then Harbor Freight have some for a couple of bucks and even less if you grab a 20% discount coupon. Boating is expensive enough without paying through the nose for everything.
