I would guess carb issues. I'm guessing the carbs were turned and idle speed was set when the engine was running on a hose. I would suspect more of a spark issue if the motor can't rev up on or off the hose.
With it being a '67, I would also carefully look at the internal wires. The insulation is probably flaking off and a wire could be shorting out somewhere.
