waybetterhd
- Jun 27, 2013
- 7
Here is the scoop.
MOD. No. CE25TECOS
i have a 1985 Evinrude 25HP Engine with a 35HP Carb and Intake installed from same year engine conversion and boat ran beautifully past two years no hickups. i went away for a bit and didnt use the boat for an entire summer last year. brought it out onto the water 2 weeks ago and ran nice. Motor started to act up due to a clogged vent on the tank. fixed issue and have had an issue ever since with the high speed when open throttle.
it boggs down once i take it over 25% throttle and sounds bad (deep gurggling), but no engine cutout. engine goes right back to nice idle when i let the throttle off and stays running. if i prime the engine with the primer beside the electiric start button with the throttle wide open, the boat takes off and skips across the water at like 30mph with smooth operation.
note: primer is taking the fuel from the bottom of the bowl on the carb, so i know the fuel pump is working and due to the fact it is brand new only 3 days ago and that the bowl is always full. Also, when the motor has a set of water muffs on it while on dry land at my house, the engine comes alive in neutral and in gear. revs and peaks out with wide open throttle no hesitation. water flow stream is constant and have no issues. issue starts in the water only while boat is floating.
I cleaned the carb out best i can, just everyone keeps saying to clean out the high speed jet. my question is, Where is the high speed jet located on the carb? and is there a highspeed needle as well? i have no diagrams what so ever on this engine or carb. i wanna take it to a mechanic, but wanna try everything possible myself first. so i can get the easy stuff outta of the way. any advice or links would be amazing. Thanks again.
list of new parts:
New fuel pump
new spark plugs
cleaned carb, but cant find info on high speed jet
new gas lines and all new hose clamps.
all greased cables and fully functional carb butterfly.
starts up with no issue and idles perfect. revs out in gear on dry land but boggs bad when in water.
Morgan
MOD. No. CE25TECOS
list of new parts:
New fuel pump
new spark plugs
Morgan
