Re: Under boat help
OK,
1st get a free photobucket acct, it lets you post the pix large & in your post like I did. That way you can quickly scan back & forth and compare 1 pix to another. And makes it easier to follow the text descriptions and see the pix all at once.
If you have any questions about photobucket & posting pix, just ask.
A couple questions:
Does the center section of the windshield close correctly? Misalignment of any kind can indicate certain types of problems below deck.
Is the hodge podge paint deliberately odd? << Does that make sense? Like weird camo or ???? Possibly poorly done cover up to change the color of the boat?
Is it ablative hull paint? <<< In Sacramento, it may have been moored in brackish or salt water, so the previous owner (PO) may have coated the bottom to protect the hull or keep algae & etc from attacking the hull.
The crack has a pencil sized stream of water draining out of it? That looks like a pretty serious crack, not likely to be just cracked paint. It is damaged fiberglass. This pix shows the crack from afar also seems to show 'pink' bondo in the red circle:
That isn't a good sign either
