Re: Pitted fuel tank--looks like salt water pitting
While it may seem logical to draw the conclusion that the salt water must be corrosive to the aluminum, it is not. Salt water does not corrode aluminum because of its neutral pH. A saltwater solution can, however, be a major facilitator for galvanic or dissimilar metal corrosion, a more complex corrosive process.
Aluminum owes its excellent corrosion resistance to the barrier oxide film that is bonded strongly to its surface and, that if damaged, re-forms immediately in most environments. On a surface freshly abraded and then exposed to air, the barrier oxide film is only 1 nm thick but is highly effective in protecting the aluminum from corrosion. Remove the source of oxygen. i.e. stagnate water or moisture, the oxide barrier can not replenish itself and corrosion begins.
Some manufactures use rubber “cushions” under the tanks. Moisture trapped between the rubber and the tank causes problems. Pressure treated wood is a known source of problems as are dissimilar metals.
