I recently discovered my tach is bad. I havent replaced a tach before and I was wondering if OEM was the way to go or do the cheaper Faria gauges work as well?
That Tach will be best if he has the System Check feature on his motor. If not, cheaper ones are avail. Normally I buy a tach to match the other gauges. If no other gauges, buy the cheapest.
