kbait
- Nov 13, 2007
- 2,449
This motor now has a 15hp carb and apparently ran fine after carb install. Brought to me needing choke to run.. I assumed a partially clogged main jet. Pulled carb and jet was clear (cleaned w/thin wire anyway and blew out). Rest of carb clean/low speed passages clear, float level when inverted. New needle retainer installed, and new fuel line pump/carb. Fired it up in a barrel, and it still needs choke-bump to keep running. Fuel pump good/fresh fuel. Pumps water from indicator fine, and out exhaust port when thermostat opens after a minute from cold start. One strange thing.. at anything over low idle, exhaust bubbles out of prop (barrel testing). In my experience, you have to get 'em revving pretty good to have enough exhaust pressure to overcome the leakage that comes out of the exhaust relief port above water. I'm wondering if this behavior is indicative of a different problem. Oh, and the exhaust chamber drain port near gearcase is clear..water drains normally when motor pulled from barrel.
Any ideas before pulling/cleaning carb again? I'll also try to see if the reeds are closing.. kinda hard to see on these motors, and I don't really want to remove powerhead to remove reed plate (if that's even the issue).
Feel like I'm missing something w/the exhaust bubbling from the prop like that..
Thanks!
Thanks!
