Re: Git Rot
I've tried GitRot several times and cut up samples to see how it works. It was too thick to penetrate severely rotted wood very deep (hardly past the surface). It really only fills the holes they say to drill. This is the same for most of the "penetrating" resins. It's all about viscosity and the thinner they are the weaker they are. Do some test samples and cut them up to see. Try pouring any of the penetrating resins though a dozen coffee filters and see what happens. Rotted wood is worse and has air that needs to be pushed out in order for the resin to displace it. In my humble opinion it's a method to use for small repair areas when you are desperate.
