SKURZ
- May 28, 2013
- 5
I'm looking for a little help/advice with the trim/tilt unit on my '86 Merc 3.4L outboard. While sitting on the trailer or while tied up to the dock the motor slowly drops down from the up position...and it's really starting to get annoying. From all the way up it will drop all the way down within about 45 minutes. I've been on here reading about manual release valves on various motors and am wondering if there's one on my big brute, and if so, where it's located. I guess I should start by checking if that's tight, then moving onto the fluid level and o-rings. I should mention that the cylinder is bone dry on the outside and not showing any signs of oil having leaked out. Any input you might have would be very much appreciated. Thanks.
