Ignition switch question
DABS
The back side of the ignition switch has 2 "M" designations on it. Are they interchangeable? On the old switch all were spade connections except one M which was an eyelet. On the new switch, all 6 are spades. Any ideas of any danger if the 2 M connections were mixed up?
Yesterday
Re: Ignition switch question
Just a thought: You might get more useful input if you gave posters some idea of which ignition switch you're actually dealing with.
carholme
On the switches with two M terminals there has to be a way to identify them. As you have seen the older ones had one which was an eyelet vs a spade. Some of them will have one M which is raised higher than the other one and this is the engine kill circuit (black with yellow stripe). The lower M is to ground (black) and they should not be mixed up.
I have a paper on it somewhere and see if I can dig it up for you as it is good reference.
Gerry
DABS
Gerry
thank you Gerry, we really appreciate it.
