I've recently acquired a 1993 Bayliner Jazz. The outdrive needs a little work before I even dare put it in the lake. THe primary issue is the reverse gate.
It is missing that is referred to as a "Pivot Bolt" on the port side. This attaches the reverse gate to the housing. It sees to be a common thread as I have plenty of bolts that I can use. However, I do need some type of bushing over the bolt in order for it to fit properly. The OEM part is NLA. Has anybody been able to find a working replacement for this bolt? I've looked at the hardware store for something like this but to no avail.
The second issue is with the control cable. The housing split open right at the bracket, exposing the stainless cable. It was obviously stuck at some point and was forced. The boat shifts properly into reverse ad neutral but the gate does not clear the nozzle completely in the WOT position. I'm sure I can probably find a universal replacement but was wondering if anyone had the correct length. Parts websites list cables of every length since they obviously vary depending on the boat. I did open the remote control box and saw a label with "Morse Controls" on it but could not make out the rest. Any leads would be appreciated.
