boatmon345
- Apr 26, 2006
- 113
I need to replace the ignition key switch on my 1997 Yamaha 150 2 stroke (S150TXRV).
It is a 6 terminal type: off-run-start with push to choke. I tried to find OEM replacement but could not identify the part number.
I tried to figure out what each of the 6 terminals are for, and identified 4 of them, but the 2 going to the lanyard kill switch are a bit unclear to me.
In any event, will pretty much any aftermarket 6 terminal key switch work? Is there any reason why this one wouldn't work?:
Ignition Starter Switch, Merc Screw - Seasense 50031153 - iboats
It even looks darn close to the one that needs to be replaced.
And what does "magneto" style mean?
Thank you very much.
