projo198
- Jul 7, 2012
- 316
This is an OMC 2.3 inboard.
Last season I had it running great. This season I took it out of storage and it started right up, and I've had it out 3-4 times with no issues.
Don't know if this is related but the last time bringing it home I got caught in a rainstorm and the motor got wet (I have to remove my cover because it blows off on the freeway).
Tried to run it this weekend and it would not start.
I checked my points gap, did some other things and finally got it to run, but rough and it died on the lake twice. When it was down I could not get spark from the ignition coil. I tried a spare new ignition coil and still had issues. When I did get spark it was very weak visually (holding the coil wire near a ground).
Even though I rebuilt the distributor last season I'm gonna start there, along with new plugs. But I'm really thinking the issue starts before the distributor. The ESA has been removed and replaced with a relay, which I unplugged to make sure that wasn't killing the ignition. I also bypassed the kill switch just to make sure that wasn't it. I am considering replacing the hot wire from the starter relay (those connections were checked) to the coil with a heavier wire and a resistor, can anyone recall how much voltage is supposed to get to the coil?
Any other suggestions to attack this problem? Though the motor was uncovered the carb cover and flame arrester was on, so I doubt I got water in the intake. I'm pretty sure it's an ignition issue.
Any ideas or thoughts would be appreciated.
