Well, though it is not as far along as I would have liked , my hull is stripped
<br />This picure shows the last little bit of the transom wood. It was all soaked. <br /><br />This picture shows the front bow storage area. This has also been removed.
<br />I debated about removing this area, but I plan to make the storage area just a little bigger. Once the floatation foam was removed I was glad I took the plunge... The foam was wet .. and the plywood on the bottom of the storage compartment was rotten.. <br /><br />This is the transom area before I disected it a lot of damage...notice where the screw goes thru .. black wood !
<br /><br />I have the epoxy ordered the wood for the stingers and picking up the 3/4 in marine plywood this week or next. <br />
<br /><br />Thats all there is for now , just glass. BTW the stringers were broken in at least 4 places. If your boat does not act right on the water (mine did the bouncy bouncy thing ) make sure your hull is not damaged. Yea I tried a lot of things to correct the problem but in my heart I knew it was something sinister. To everyone ... PLEASE dont let this happen to you buy a cover for you boat .. prop the nose up and remove the drain plug. Put a fan under the cover .. ANY thing to keep the water from laying stagnent in your boat !! BTW if you screw anything to the floor I recommend running the screw in running it out pouring epoxy in the hole then run it back in (more epoxy on the head please ). Every place there was a screw thru the floor it had a area 6 inches around it rotten !!
