Re: Putting new floor over ols one? GLS 195 Sea Nymph
I'm not a boat rebuilder or rebuild hobbyist. I've replaced 2 plywood floors in tin boats. One was a 18' Starcraft center console (extemely easy), and the other a 19' Sea Nymph GLS (a little harder). Putting a floor on top of a floor may seem like a good idea, but it is not for too manypractical reasons to go into here. I used high grade exterior 5/8" plywood (not marine), traced it using the old flooring, painted the cut pieces twice on both sides and edges, and installed it with ss screws. I glued down and stapled at the edges a thick synthetic sheeting used to cover concrete patios (ie UV resistant). Do not, repeat, do not, just put a new floor on top of an old floor. If you have the skill to do that, you have the skill to replace the current floor.
