Closed (salt water cooled) system, heat exchanger ok. Isolated each side and when coolant is poured into each sides respective hose from the heat exchanger (actually the return coolant line), coolant goes out exhaust purely by gravity.
Replaced one riser and still leaks. I presume that sides manifold is bad and the other sides riser and or manifold is also leaking.
Is there anything I may be missing before we replace both manifolds and riser?
Thank you.
Thank you.
