BlueFishCrisis
- Sep 7, 2010
- 96
I burned through the exhaust hose in the engine compartment of my 89 Bayliner. It has the 125 HP L Drive. I pulled the exhaust manifold and found debris clogging the stinger that keeps the pipe / hose wet. Compression is in the 130s to 140s in all holes. Cleaned it all up, ordered a new gasket, and am getting things ready to re assemble. Question is - Can I use a piece of radiator hose to replace the one with a hole in it? The size and construction are the same, but the wall thickness is a little smaller....??
