Yamaha timing
geo7
Hello, I have a Yamaha 3 cyl 30 hp 1991 two cycle electric start engine. I would like to check the timing and would like to know it I can use an automotive timing light? Also can I use an automotive tachometer or do I need one for a two cycle engine?
schematic
Re: Yamaha timing
you can use a automotive timing light, but an automotive tach won't work
99yam40
Re: Yamaha timing
Just in case you have problems getting it to work, I had to reverse the clamp on lead for my Snapon timing light where the arrow pointed away from the spark plug for it to pick up the signal
geo7
Re: Yamaha timing
Thanks for the replies. I have never timed a two stroke engine and did not know. Thanks again.
