Re: How to change starter on 1998 larson 186 sei w/ penta 4.3
I believe we have the same boat. The big trick is to use a 8" extension no swivel. Once on the bolt you will have only two inches of wrench travel hopefully the bolts will snap loose and you can use your finger's to turn the extension and bolts off. The hard part is getting the right angle to turn the wrench installing the new bolts are a breeze. You may find it takes gymnastic's to get in the right postion
