Hey guys, I got the boat running. I ended up with a regular 350 I bought from a guy for $300, it has a little cam it sounds like and an edelbrock aluminum intake. Engine runs good and sounds nice. Now I'm working on my electrical gremlins. I took all the solenoids loose and cleaned all the connections, now my tilt motor is working pretty good, but I have trim issues. I put a new motor on the trim housing, It was the cheapest one I found, $175 This may be where my problem lies.
Anyways it worked, but was slow when I first installed it, I trimmed it all the way up to test run my new motor and after the test run I was running the tilt and trim to see if everything was good to go. The trim wouldn't do anything, I can just hear the solenoids click. SO I took everything loose and hooked the trim motor to a spare battery so I knew it was getting good juice. Anyways still no luck. I helped the motor up to the low trim position using a pry bar while the juice was to the motor. It was very slow even with me helping it.
BUT, when inspecting stuff, I found that the bottom of the trim housing where the screw bottoms out has busted loose. I felt around and I don't think this is a big deal at all, seems it just keeps the weather out of the screw and bottoms it out. SO is my trim motor too weak, or is the housing screwed, or both?
And if I don''t fix it, where do I want to leave it so the boat performs the best? Is it worth fixing? I noticed the motors that may be better quality are about $250.
Thanks, Sam
Thanks, Sam
