I have was just given a 1991 bass tracker pro 17 with a 25hp Johnson. The problem is I can't find a way to advance the throttle while in neutral. The boat has the tracker side mount controls with starter key and safety kill switch but no obvious way to advance the throttle without shifting into gear. Thank you for any help you can give.
