1971 19 fuel guage woes
H20wens
I don't imagine that I am the only one with a broken 40 year old fuel guage. I recently had the fuel tank out of my boat. I should have replaced the sending unit while I had it out, but it was working before taking it apart. I must have damaged it somehow. Anyway, anybody know where I can get a new sending unit?
gm280
Re: 1971 19 fuel guage woes
You can do an ohms test across the fuel sender/wires to verify that the fuel sender is the problem before going to much work to remove and buy a new one... Could just be a bad wire or correction or something else that simple too... Also check the meter to make sure it works properly as well. No need in buy parts for no reason...
lamphega
I purchased an adjustable fuel sender that can be set for depth of thank and it has worked for me. They sell them here. Teleflex Universal Fuel Sender.
aristocraft
on all the current restorations we are doing, we are replacing them with the new WEMA senders 11.5" they are great
