BrandonC83
- Jun 21, 2013
- 21
I will start from the beginning.
I just bought this boat last week and I am trying to troubleshoot all of the little problems the boat has so please bear with me.
My issue right now is the trim is not working, at the beginning I had power going to the relays but nothing coming out and the trim would not work. So I bought two new relays and replaced those however as soon as I connect the power the main 50 amp fuse blows, every single time since I have installed the new relays when I did that I could hear a clicking noise when I pushed up/down from the control panel even though the main fuse is blown.
I did match the wire numbers to the numbers on the relays so I believe the relays are hooked up right. The clicking sounds like it is coming from each relay depending on which way up or down you push the trim control.
Would appreciate any help or ideas on what may be causing this?
