Hello,
I am new to these forums (been lurking for some time gathering info), and even newer to outboard "stuff." To say that I know less than nothing about engines is true.
Anyway, I picked up a 14' tin boat from a guy and got a couple of things thrown in with the deal. I received an older game fisher electric trolling motor, a 1960 Johnson QD-21, and a 1955 Johnson QD-16.
The QD-16 is in the nicest shape and the engine I want to play with at this time.
I know that these motors were originally setup to use a pressurized tank. This one appears to have been modified. Please look at the pictures and let me know what you think. I am almost sure that the thing in a couple of the pics is a fuel pump (that and there is a newer style fuel connector).
Where do the connections for the pump go? I would think that "in" is from the tank, and "out" is to the carb. Where is the pressure connection? Also, does the original pressure connection from the tank need to be plugged?
Anyway, any thoughts, or general chatter on this thing would be appreciated.
