Went to the river and this happened
fordmugg
Went to the river last weekend and 20 minutes in going down to the sand bar I lost compression and started running real rough, limped it back and when I got home did a compression check and a leak down check, comes out I bent 2 intake valves, so now in the process of getting it fixed so I can be back on the water
Don S
Re: Went to the river and this happened
Don't just fix the valves, find out why you had two bent intake valves. Probably tuliped valves, not just bent. I would guess improper timing, over propped and lugging, running lean or all of the above.
fordmugg
Yeah I'm gonna go through it
Ayuh,... Check the fuel filter for water, 'n debris,...
redone76
bummer that happened. Have you got her fixed up and back on the water?
fordmugg
Yeah I just got her back together and took it on a test run on Tuesday, the boat ran awesome, I replaced the bad valves and went ahead and lapped all the valves in. The cause was I had 2 loose spark plugs that leaned out the cylinders and caused the intake valves to distort, but a little bit of work and she is running, here it is when I fired it up
http://i25.photobucket.com/albums/c64/mugg9mm/IMG_2299.mp4
