bcherrington
- Jun 20, 2013
- 2
So, I decided to do a bit of maintenance on my manual shift Stringer drive before heading to Lake Powell and have had quite the experience.
I have twin Stringer drives on my boat and knew the impellers had not been changed since 1987, so I had this crazy idea to go ahead and replace the transom boots and impellers in the drives before heading to Lake Powell this year. Well needless to say I should be on Lake Powell this very minute and I stuck home trying to figure out why I am not able to get one of the upper gear case sealed up so water does not enter and mix with the oil. I am not proud to say it but I have pulled that drive off 7 times now and it is getting a bit old and frustrating, I have definitely increased my removal time down to about 20 minutes. lol
Anyways, I am hoping a Stringer expert will chime in and help me out so I can get to the lake this year.
1. I have a Seloc manual and maybe that is my first problem, is there a better manual out there for rebuilding the upper gearcase?
2. For the life of me I can not figure out how water is entering the upper housing with only 5 to 10 min. of run time on muffs when I can pressurize the upper to 15 psi and have no leaks when submerged in water.
3. I follow the manual step by step and I have replaced all seals and it is still leaking. Is there a magic glue or permatex that I am not aware of? I have tried permatex aviation gasket, permatex #2, and gasket sealant and nothing has worked so far. It is not that complicated and I had no issues with my other drive that I replaced the impeller in.
4. When I run the boat on muffs alone doesn't that eliminate half the seals? Where should I be focusing my attention... I have ended up replacing all seals and o-rings throughout the upper trying to find the leak.
5. I am using permatex #2 (non-hardening) on both sides of the impeller plate 1/4 inch down, plus the impeller housing, and the bolts like the manual describes. I must simply be doing something wrong.
Thank you up front to anyone that might point me in the right direction.
