Re: 85hp force dies "usually" when you give it throttle but not always.
Unless you just want to do the rebuild on the fuel pump and carbs, I recommend doing more troubleshooting to at least isolate the problem area. First is it electrical or mechanical, i.e. fuel related, loss of compression after engine heats up, bad reeds, sticking carb floats, etc. The easiest area to isolate is electrical by just watching the sparks with a timing light. Obviously, if the strobe is not constant there is misfiring hence electrical is the source of the problem. Even better is use a $5 spark tester to test the strength of the spark on each cylinder. If the strobe is constant at all RPM's then the source problem is mechanical.
Then isolate the fuel system first by watching the priming bulb if it deflates, installing a see-thru fuel filter to see if the fuel pump is delivering fuel properly (if not check fuel filter first) and the carbs. You can tell if fuel is being delivered into the cylinder by checking on the plugs. Any plug that is wetter than the rest is mostly not firing properly (indicating electrical problem) while the drier one indicates improper fuel delivery. You can use a spray bottle to directly spray to a suspected carb not delivering fuel and should notice a change in RPM when you spray into the carb or carbs.
If there is no change in RPM, then most likely the problem is neither fuel or electrical but could be the reeds. But if the reeds are not operating properly, you should see blowback of fuel mixture to the front of the carb. You can test by activating the kill switch to make sure the engine doesn't start and then placing your palm against the front of the suspected carb (cover only half of the front like you are choking it), crank the engine and you should only feel suction and no blowbacks. Try not do this too long as it will flood the affected carb. Any indication of blow back is an indication of improperly operating reeds.
Remember, only do the troubleshooting while the symptoms are present or when the engine is acting up. Personally, I believe it is electrical but you need to confirm it through troubleshooting first. There was a similar case posted before and it finally turned out to be a rubbed out trigger wire rubbing against the trigger housing that was causing the misfiring.
