Xtremesledder
- May 22, 2013
- 15
Hello new here and been reading a lot of great info on this site . Here is my issue -1986 4.3 cobra I replaced the bellows and lower shift cable have read Stuart Hastings article over and over as well as many threads here . Using this info have set the cable to all the correct dimensions as well as the 90 degree angle on the bell crank. I reinstalled the outdrive adjusted cable from control box and when shifting into reverse the shift interrupter will stay on the high point of the W . I readjusted to eliminate that issue now it won't engage reverse. Readjust to get reverse it seems it will not fully engage forward . I have repeated all adjustments many times with the same results .
Any help or ideas would be greatly appreciated!!!!!
