I am having trouble with my 1988 28hp Evinrude which led me to cleaning and rebuilding the carburetor. The rebuild kit comes with a couple of metal disks which after doing a little research appear to be soft plugs. I initially did not remove the old plugs to install the new because I wasn't sure how to get the old out or how to install the new. I just replaced the float, needle and needle seat and the gaskets. I also cleaned everything with a spray carb cleaner and then blew it out with compresses air. Before I did all of this, It wouldn?t even start. Now it starts ok, but will not stay running when I open up the throttle. It may run for a couple hundred yards before it sputters and then dies. I then usually have to squeeze the primer ball to get it to start again. The boat seems to idle ok for long periods of time. Is there something I missed by not removing the soft plugs? How do they come out? Do they just press back in? Or is there something else I should be looking at?
Thanks for any replies
Cretch
Cretch
