I've been trying to get this motor to run correctly. I went through the carbs, replaced the fuel pump diaphragm, but still couldn't get the motor to run while in gear.
I followed all the procedures to do a link and sync using the directions from Clams Canino. However, I have a couple of questions.
1. It says to set the initial pickup at 3-4 degrees btdc. Is this when the throttle butterflies are just about to open, or are they at the stops?
2. When setting the initial pickup, the adjustment screw for the advance is screwed all the way in. Is this normal?
Thanks in advance for any help.
