My boat has a 1993 4.3 4bbl engine and Alpha 1 Gen 2 drive, the engine does not have a serial number. Recently the trim pump has been acting up, as of yesterday one of the flared fittings on a hose to the pump started to leak, the fuild coming out was not clear and look a lot like engine oil. It seems to take a long time to lift the leg and when the leg is fully up or fully down, the pump does not slow down or labour at all...it used to change sound when it went into bypass (as I'd expect in any hydraulic system) at the end of the cylinder travel.
The pump assy is merc P/N 93247A7 but since the motor, solenoids and wiring are fine, I'd like to either replace just the pump (or pump & reservoir if thats the only way they come) or rebuild the pump. What are my options for this work...
I was a bit surprised at the cost of the full assembly (~$800 for the saltwater unit), it seems like a lot for such simple technology.
Thx in advance for any input.
Zeke
Zeke
