The engine was running fine today then all of a sudden I heard two pops and the boat lost power and started knocking. Checked spark plugs one was loose, and upon inspection it had gotten hot and almost melted. All plugs pointed towards the engine running lean. I have not taken the valve cover off to see if it dropped a valve or its a rod. The engine has good oil pressure (35-40) at Idle and revvs its still around 60. The engine starts right up, no loss of oil, no metal shavings on dipstick. The oil is not milky either.
Maybe I'm getting ahead of myself, but I've started looking at a replacement engine. Ive found a few used 188's etc, but what other engines will "Bolt right up" to the MC-1?
Thanks,
Easy
Thanks,
Easy
