Yamaha 200 charging system question
pbolden
Hello Everyone,
Does anyone know about the charging system on a Yamaha F200TXCR 4 stroke 2004. Will idling for a hour recharge a nearly dead battery?
Thanks,
Paul Bolden
Don S
Re: Yamaha 200 charging system question
You have a 45A charging system at cruising rpm. I would guess maybe 3 to 5 amps at most (probably less) at idle in an hour. Wouldn't amount to much of a charge on a dead battery.
pbolden
Thanks Don S. Very valuable info to know.
Paul Bolden
Capt Ken
You actually have a regulated system and the engine will produce a full charge at any rpm.
Don S
Even car alternators are regulated for voltage, but rpm controls amperage produced.
99yam40
either way it is not a good idea to run a dead battery in anything,
it is hard on things. Charge it up or put a charged one in it's place
pbolden
Thanks guys,
I'm going to pull it and charge it.
Paul Bolden
