hi gang. did some searching but would like to clarify some points. just picked up a 1969 Merc 500. it's a 4 cyclinder, 2 stroke, 50 hp engine.
the older gent that had it said he hadn't run it in over 15 years. it started right away but no water was coming out of the 'pee hole' other than a few drops. so we shut it down.
i have taken the lower leg/gear case off and thought i would change out the impeller etc.
the impeller (i will still change it out) was in good shape, not torn etc., and seems to have been installed in the correct direction. so guess some of my questions are:
1. this engine does not have a thermostat correct? i can't see one anyways - and from what i read thermostats only started around the '76 models?
2. should water be expelled from the 'pee hole' on idle, or only when revved?
3. i have blown through the water tube and can hear air escaping but it does not seem to blow out of the 'pee hole' when blowing from below and when blowing in the tube from above it does not seem to be coming out the water tube that goes to the impeller housing. (hoping the power head doesn't have to come out to check fittings there).
4. when draining the oil from the lower case, there were no washers on either the fill screw or on the drain screw... there should be washers on both, shouldn't there?
thanks...
thanks...
