The_Other_Dave
- Aug 30, 2012
- 34
Finally I get to post my - "Is my engine running right w/ correct prop thread"
So here is the story.
I own a
`99 Monterey 180M
4.3L Volvo 4.3GL PWTC 190HP
SX-M Outdrive P/N 3868893 1.79X
Solas 14.5"x19" Amita
I run it at 5000+' feet
Purchased this boat last fall. First boat since being in my 20's (20 years ago and they were old boats even then). Made 2 trips out on the water and then put the boat away for the winter w/ end of season maint. I have had it out 4 times this year with a bunch of upgrades and maint between then and now.
I has 330 Hours indicated on the hour meter w/ an engine change at about 300 hours due
to the previous owner delaying the winterizing a little to long and cracking the block.
Since purchase I have:
Changed the oil (Merc 20w50)
Changed the outdrive oil (Volvo synthetic 75w-90)
Changed the plugs, cap, rotor.
Changed the propshaft output seal (it was leaking).
Greased the U-joints (they looked and felt great with no rust at all).
Checked engine alignment (smooth as silk at 0-90-180-270 degrees)
Compression tested, all cyl 165+/-5PSI (which seems good due to my operating altitude)
Greased the transom bearing (felt as smooth as glass).
Changed U-joint bellows.
Changed exhaust bellows (and found the exhaust flapper valves in the lower unit).
Replaced the impeller pump.
Replaced the somewhat rough MW 14.5"x19" prop with a Solas Amita 14.5"x19".
Installed a keel-guard.
Replaced the Series 24M battery with a 27M battery (the old one was 5 years old).
Replaced the thermostat (old one was shattered and would never let the engine get above the minimum line on the temp gauge)
Polished and waxed the entire hull (it had a fair amount of oxidation).
So here is the question.
This past weekend I finally had the combination of boat in good enough shape, small enough waves,
wife in a good enough mood to ...... LET ME MAX IT OUT!
This was done on fairly smooth water at 9AM, 70Deg F ambient, engine warmed up to 125F, 2 adults and 2 teens (+ gear) + gear, full tank of gas (20 gal).
Do these numbers make sense?
Here are the results at WOT.
4200 RPM indicated (this is a calculated 50ish RPM low based on testing it in the driveway against my digital tach at 2k RPM engine speed....I don't want to rev it to high on muffs)
Trim 50% up
40.2 MPH (Measured with GPS)
Trim 75% up
42 MPH
Trim 100% up (Started to get a little porpoising)
42.5 MPH
Lower throttle settings.
3500 RPM indicated (again a little low to reality)
Trim 0% (full down)
30.3 MPH (GPS)
3000 RPM
Trim 0% (full down)
23MPH (GPS)
Overall I think I am satisfied with the performance (which I guess is all that counts)
but I have noticed a few things.
1. I have gotten some pings (1 or 2) from the engine if I go from idle (in gear) to WOT really fast.
2. This engine combination runs really cool. It seems to have trouble maintaining 150F even with
a new thermostat (admittedly water temp is only 60-65 degrees right now).
3. The RPM at 20MPH-ish seems a little high.
Could this combination benefit from a different prop? Not wiling to go SS but might try a different
diameter/pitch. Main use is blasting from one swimming/fishing cove to another and pulling tubes/skis/wakeboards
and other toys with my kids on them. My main lake is 7 miles long and 1/2 mile wide so long distance cruising isn't going
to happen.
Does this system sound like it is running OK overall?
Thanks,
Dave
I own a
`99 Monterey 180M
Trim 50% up
Trim 75% up
42 MPH
42.5 MPH
Trim 0% (full down)
30.3 MPH (GPS)
3000 RPM
Trim 0% (full down)
23MPH (GPS)
to happen.
Thanks,
Dave
