Hi I have a 1977 Evinrude 70 HP 3 cylinder OB that has me a little stumped and I am hoping for some feedback and suggestions to fix her...
To start off with, this OB is on a 1972 16 foot Baja that my son purchased about 3 1/2 years ago... when we got it it ran OK, but seemed a little lacking in power..
I did head gaskets, thermostat, new coils, plugs and wires (one of the old coils was arcing over at the coil so it was decided to change all three) I also rebuilt all three carbs and replaced all the fuel lines under the cover...It ran much better, started up on first crank and made a little more power, but was still a little weak..
Two years ago, I "spun" the prop in the hub (and thought that might have been the lack of power problem) and replaced it with a new prop that has a replaceable hub in it, pitch and diameter were checked against all specs for the boat and engine and still it was weak..
Later that season I noticed that occasionally the starter would hesitate when starting and became concerned... long story short, there was a leak in the exhaust manifold that had caused water to get into cylinder #3 (bottom)... I removed & rebuilt the exhaust manifold, new gaskets and all the trimmings.. when I had the exhaust manifold off I noticed the sides of #3 piston were a little scored up and determined that this was probably why the engine wouldn't make the full 70 HP it was supposed to... at least I had my answer and it was confirmed by a compression test... #3 was off by more than 15%... so I accepted the fact that this wasn't going to be the fastest boat on the water, but it would be OK as long as the piston didn't get any worse...
The engine ran like a champ for the rest of that season and never gave anymore trouble with water intrusion after the exhaust manifold was repaired... Winterized it and fogged it and put it away for the winter....
My son joined the US Army last April, and in all the commotion and stuff, the Baja never got used at all... it sat all last year waiting to get it's bottom wet again...
Fast forward to two weeks ago, and I got the trailer out, and took off the winter cover and got the OB and boat ready for this season and my son's return on leave from Ft. Carson this July 4th... figured he would like to take his old boat out for a ride and have some fun...
Now for my problem (sorry it took so long to get here, but I am stumped and needed to vent a bit...) The OB sprang to life within three or four cranks after fresh fuel was put in the tank and a new fuel hose was installed .. ran it on the "muffs" for about an hour to make sure that the water pump and thermostat and everything else was OK.. changed the lower unit oil and decided to take it down to the launching ramp for a "spin"...
After launching, as I was trying to leave the dock, every time I put it into gear it stalled.... I had let it warm up for about ten minutes and the thermostat had opened and closed a whole bunch of times as evidenced by the water out the two holes in the lower unit...
After a little while I determined that the OB was only running on one cylinder..... #2
I couldn't get it to make any power when I did manage to get it into gear and try to throttle it up... put it back on the trailer and drove home in a "mood"..
Got back home and got out some tools, removed the airbox and checked the carbs... first I checked all the bowls for fuel... all had fuel... started it up (on the "muffs" again) and let it idle around 1200 RPM.. I figured the first thing to try was to open up the top jets of the carbs one at a time ... removed the screw and then loosened the jet and shot a little carb cleaner in to the jet ports and see if that got any results....
I removed the cap screw from #1 carb and nothing happened to the RPM's... I then tried #2 and the engine died...
restarted and tried #3 and no RPM change...
So I figured that I needed carb work again... cleaned the carbs as best as I could without fully removing them, but I still had a feeling that there was something else going on...
If I placed my palm over #1 carb as the engine was running, I would get vacuum at the carb and it would draw fuel up out of the bowl and "flood" the carb, but I couldn't get Cylinder #1 to fire....
If I "choked" #2 as it was running, it would stall from too rich mixture...
If I "choked" #3, I got FIRE in the cylinder as evidenced by RPM increase, and some extra smoke from the exhaust.... but it wouldn't keep firing on #3.... it would eventually go back to running on one cylinder.... now that was OK... it meant the #3 carb needed more attention and probably a good soak and ultrasonic cleaning... this wasn't going to be a problem... cylinder #1 however was giving me a headache...
I couldn't get #1 to fire AT ALL!!! i tried all sorts of things including a quick shot of ether down the throat of #1 carb.... NOTHING!!
Figured that I might have fouled plug or a spark issue now, so I pulled the plug and checked the spark.... it jumped almost an inch and a half when the engine was running on #2 cylinder.... OK, the spark is good...
Lemme try a fresh plug, in case the old plug is shorted or badly fouled..... NOTHING!!!
Now I was getting perplexed.... I started thinking , reed valves, cracked block... etc... If I "choked" #1 carb while it was running AND I had no spark I should see a wet plug when I pull the plug out, right??? Even if I sprayed something into #1 carb while it was running, I should see it on the plug... The plug kept coming out dry...
I can't think of any reason why a fuel charge won't pass through to the top end if you have vacuum at the carb (which would mean that the reed valves are closing and opening)... the ports in the cylinder walls control the intake and exhaust timing.... so unless I am missing something here I am stumped.....
I haven't done a compression test yet as that would tell me how bad the rings are, which wouldn't keep it from firing, just keep it from full power...
HELP ME!! I am stumped
I apologize for the LONG story, but I couldn't help it, I'm frustrated...
Any Ideas???
Rich
Any Ideas???
Rich
