I have a 140, 3.0L 1986 Mercruiser engine. Wiring up the throttle cables after an engine pull and transom restore accidentally pushed the lever the wrong direction and it jumped its fitting inside the carb. I have not opened it up yet but would like to source that parts. My 25. Accelerator Pump Lever does not seem to be stripped.
I'm looking to purchase 16. Pump Shaft & Lever Assembly
Mercarb Marine Carburetor Exploded View | Mikes Carburetor Parts
I'm also guessing i would need a gasket, should i rebuild the whole thing while I'm at it or avoid possible trouble?
Any other advice would be appreciated.
Thanks Again!
Thanks Again!
