If anyone can help it would be greatly appreciated. Ok my 94 175 xri efi is lost its mind. I could take it out rite now and it would run like a brand new motor, however every once in awhile after shutting it down it refuses to start back. Now the wierd part when it does this and I load it up and drive home a 5 min drive as soon as I get it home and put it on the muffs it starts up and runs perfect. Its done this around 5 times, the same result each time.
The fuel system is so clean you could use it to make moonshine. Ive been through it. Its hard to know what to look for because I cant catch it during one of its spells. The engine acts as if its flooded but its EFI so should not be so. There is no hesitation in the reponse of the throttle, no lack of rmps (5800) Like I said it runs fine if it starts.
Help please as this is making me pull my hair out!
