Any help would be appreciated.
My tilt/trim was working poorly, sometimes not raising the motor at all, when it did with annoying noise. I noticed it was leaking through the top seal and losing fluid. Every time I filled it everything worked fine. I took everything apart and ordered the seal, backup and wiper and replaced them. Put it back together and now it will not lift.
I have since ordered the seal/o ring kit and have replaced them all. I replaced the quad seal and backups on the piston as well. The electric motor runs, backwards and forwards at speed with no noise. Seems okay...however when everything is connected the boat motor will not go up. The battery is also brand new.
My questions:
1. Is it most likely the pump assembly? Since I have just about replaced everything else?
2. Since I pushed the motor up (helping the motor) quite a few times, is it likely I pressure-blew something?
3. The manual valve keeps the motor from falling the last four inches or so, but it will not hold the motor up at any other spot. Is this likely related to the pump assembly, or could the manual be blown somehow (I have replaced the O rings, lubricated them, and nothing seems out of whack).
4. Is there a way to check the electric motor. I would hate to install the pump assembly and find it is the manual valve or motor.
Thanks for the help if possible! I am handy mechanically, but do not want to order the wrong parts. Would prefer not to take it to a mechanic and pay the labor charges.
My questions:
