Re: headliner question
A good quick fix is to take off the old covering, and sand the surface with something like 80 or 100 grit sand paper to knock off all the big stuff and get it sort of flat.<br /><br />A automotive upholstery cloth supply house will have the 1/4" or so foam padded, velvet feeling headliner material they use in cars. <br /><br />It usually runs around $15 a running yard.<br /><br />Get a can of spray glue, 3M #8080 is good. Spray the ceiling, and the foam material both. <br /><br />Its better with two people to keep it sort of taunt, and stick it up there starting in the center and pressing towards the outside edges.<br /><br />Ideally, take the ceiling pannel down and do it on a table, but it it won't come out, it can be done in place.
