I have a 1979 Sea Star with a 2.5 liter OMC 120 engine and 400 series Stern drive. The engine is GMC inline 4 cylinder. Model number of engine is 990243S. I worked on the boat over the winter and started putting it in the water this spring for the first time. The boat is new to me, never saw it run before I bought it. Had several basic problems which I repaired and was able to get the boat up and running on the rabbit ears in the driveway earlier this spring. Motor ran great after warming up and all was well. Problem after we started taking it to the lake we noticed almost right away the motor would start to get hot (Over 220). If you run it long enough the motor will begin to knock and diesel when you try to shut it down. Only would cool down a bit if you were cruising at about 3/4 throttle. Stopping and starting it just got hotter and hotter. I finally found a drum big enough to test in driveway so I could test without rabbit ears pumping water into the inlets. Found right away that it does not pump water below about 1800 RPM. Over the winter I had the Outdrive disassembled and replaced the water impeller and all the gaskets and worn parts. No trouble reassembling, and everything looks to be in good shape. Still puzzled as to why it will not pump water at lower RPM. I did notice however that in the past someone had used a fair amount of sealing compounds around some of the parts. I did not make any extra effort to add to these compounds as I was certain I replaced all the proper gaskets and seals. Has anyone ever heard of this model having internal leakage problems between the inlet water passages and the outgoing exhaust that would be causing a deficiency in the water flow?
