Olias
- May 28, 2013
- 99
Ok, getting really frustrated and don't know what else to try now. Been working on this 60' Evinrude 10hp Sportwin for like 3-4 weeks solid now. Did a compression check (80 psi on both cylinders), did a carb rebuilt kit on it, including a new float, got new spark plugs, gapped the points, re-set the two needle valves according to the manual (1 1/8 turns open and 1/2 turn open) and also got a new flywheel. Thing is, even though I have yet to get it to run I have had good spark from the get go. This was verified both visually with a spark plug checker as well as me actually holding the darn wires and getting zapped. I've gotten tons of "pops" and smoke etc., signs of aaaallmost starting but not quite there. Here's my quandry...while waiting for some parts to come in I had removed the wires that come from condenser and coil and screw onto the points post (or what ever it's called) and had them off for a week or so. So when I went back to hook them up I realized that there are actually 3 wires on each side now. The green one from the coil, a black one from the condenser, and now another black one (by each set of points). In another post I mentioned this and someone said yes, that is correct IF you have a "kill switch". I do. I have traced them back and that's what they are. I just don't remember having 3 wires hooked up to the same post when I took them off. Ok, no big deal just hook em' all back up, right? Well I did and now I have NO spark on either wire. So my question now is....do they have to go onto the post/screw in a certain order? It's almost like the kill switch wires are not letting current get through or something. I currently have the wires (on both sides) hooked up in this order....kill switch wire, green coil wire, then last on the outside the condenser wire with the screw through all those. Does it matter? Does the kill switch wire need to be on the outside or in between the two other wires? ANY help/suggestions would be GREATLY appreciated. Thanks
-B-
-B-
