bitesomthing
- Jun 12, 2009
- 27
Ok heres my issue.
1994 proline 17ft center console.
Bait tank is in front of console.
Just got boat 2weeks ago I replaced the old pump which was a 800 gallons per hour (800 didnt have much volume either is why i changed it)pump with a new 1100 gallon piranha shurflo pump but when I turn on the pump while on the water/ ocean I get very little water pressure to tank. I also have 13 volts at pump wires with motor off.
From pump to tank is about six feet with about a 2ft elevation rise.
About a 10 minutes fill time.Thats with wide open valves.
I also had to reduce out flow hose from
1 1/8 inch down to 3/4 inch hose. I figured the smaller diameter hose may restrict the volume of water, but thought i would have better pressure.
Where did i go wrong and what can i do to get better vole of water from pump?
Im sure lots of guys have bait tanks in front of center consol and have plenty of water.
If so what pumps are you using?
Thanks
Chris
Thanks
Chris
