Hi, I have a 82/83 Wellcraft V20Sl. Has a four banger engine and 280outdrive. I have a Clymer Book and I am trying to find the sending unit for the tilt system. Clymer is vague and in one instance says lift the drive, and turn all the way to starboard to expose the sending unit. Another section says it is under the steering helmet, but begins with lifting the outdrive almost the max and then removing the helmet. I don't think that is possible as the helmet is not much exposed when the outdrive is up. All I want to accomplish is to adjust the sending unit so the gage on the dask gives a more correct indication of the outdrive position. Any help. I am in Baja, Mexico and there is not much technical help here.
Sam
Sam
